chl
- First Name
- CHRIS
- Aug 13, 2026
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
I think Ford should replace the batteries, but only if defective, I agree with that.Thanks for that info.
Not only do I think Ford needs to address the root issue and replace all suspect batteries like Chevy did with the Bolts, they need to compensate owners for loss of value.
Short answer. No I can’t trust Ford with the Fathom. Their actions, or more specifically inaction, speaks louder than anything they say.
Ford determined/estimated that only about 1% of vehicles are affected, the new software will trigger a replacement under warranty if the defect is detected, and replacing every battery when only a small number are affected would be wasteful and there is not a sufficient supply to do that.
Ford is compensating owners for the reduction in range with extended warranties until the batteries need replacing.
It may not be what you want, but it was a business decision with tradeoffs, a compromise if you will.
