Physical Dials Confirmed?
Are we done with the touchscreen controls experiment? This was the hidden image in the latest video.
It could also be a teaser for the audio system's quality.
Ranchero EV Pickup Truck Physical Dials Confirmed? 1795619613299-yg
dan_meh
Daniel
Alexandria, VA
2024 Mustang Mach-e Premium Extended AWD
Physical dials and buttons (as well as a less painfully laggy car OS) are a reason for me to upgrade my still low mileage Mustang Mach-e. Maybe not in the first year, and not into a pickup truck, but hallelujah if true.
VW got the memo, GM never fully abandoned button life, and if Ford is correcting, then we have a quorum.
A fully touch interface isn’t a deal killer (obviously… I own a MME…) but buttons are an advantage.
I like buttons. Physical buttons. But buttons cost money, and Ford is trying to keep this thing cheap.
atomguy245
Doug
2022 Ford Maverick
They could just use an off the shelf button system like they always do. Ford rarely designs unique climate control buttons for each model.
TRU-BOOST
Too many
Touch controls dont bother me when well executed. Modern Subarus for example just make sense. Granted their system is a bit laggy, especially at startup. But the HVAC stays on the bottom at all times and there are quick tap icons for heated seats, wheel, start\stop, brake hold. Getting into my coworkers Elantra on the other hand is a sea of buttons. Visually that looks bad IMO. A volume knob, temp +/- and fan speed would be the only buttons I like to see. But if given permanent spots on the screen, Im fone with that too.
Personally, using touchscreen controls isn't as bad when you have a vehicle that can mostly drive itself (see: Tesla). However, when you have to maintain control of a vehicle at all times, a dial to adjust the temperature is better than fumbling with a touchscreen that makes me take my eyes off the road, even for a second.
And again, it could simply be a hint that they are not sacrificing audio quality to hit the price point.
TRU-BOOST
Too many
My son has an old 2004 Crown Vic that he loves and refuses to get rid of that he uses as his work car. Its a 2004 LX trim and has HVAC controls on the steering wheel. That needs to make a comeback..!! We dont really need 5 buttons to control cruise control. Just a button to turn it on and an +\- toggle. All the other junk like lane centering, following distance, etc can be in the screen. Once you set it to your preference most people never touch it again.
UEVenthusiast
2020 Ford Escape Hybrid
I found something interesting when Ford first dropped the 'beat the heat' video and it makes me wonder if there will be a separate physical control for volume. I sure hope there will be.
If you look closely in the top left corner, above the computer in the foreground, it looks like a Sync 4-esque interface with a digital volume control. This was taken away from the video yesterday, so that you can only see the engineering computer.
Ranchero EV Pickup Truck Physical Dials Confirmed? IMG_6506
