- First Name
- CHRIS
- Aug 13, 2026
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
Hopefully, Ford thought about that and has a solution, lol.DC to DC fails? Yeah....maybe SOL. But if we make some assumptions from how Tesla does it for the CyberTruck....you can jump it with a 12v jump box or other 12v based vehicle with regular jumper cables. It boosts the 12v to 48V internally so the 48v electronics can run. But if the DC to DC is already fried....then you couldn't even get as far as jumping it at all. Right? I suppose I have the same questions you do......
I guess it depends on whether the same DC-DC converters are used for whatever jump facility they provide...however...
If you step up the voltage from 12v to 48v, the current output steps down, unless you have a boot converter which will regulate the output voltage and current, but will draw more current from the source as needed.
The limit is how much power the jump source can supply (I x E)... and for how long.
A car 12v battery has a CCA rating (Cold Cranking Amps), which is a measure of how much current it can supply in a short period of time to crank a gasoline engine at 0 degrees F: 30 seconds at 0F temp and stay above 7.2V.
If you are jumping from a running ICE vehicle with an alternator, the limit is the rating of the alternator plus what ever current the battery can supply should the alternator limit be exceeded.
Most passenger car alternators can supply something like 50 to 150 amps (according to a search), which peaks when revving the engine. So that is the continuous amperage a typical car can supply when jumping another vehicle, and apparently real world testing says that is what is typically used when jumping a vehicle.
So how many amps would the Fathom require to boot up the systems with a jump?
We don't know.
F-150 Lightning jump start:
