Boulder, CO
Mach-E
Andrew Frick, president of Ford’s Model e division, recently told the Detroit Free Press that the top Fathom model will be priced under $40K.
“The starting price of $28,350 is just that,” Frick said. “We’ll have a range that goes to the high $30,000 range. And we’ll have a couple of different offerings within that."​
Frick said more details on the various trims / models will come closer to launch.
Public version of article (via Apple News):
https://apple.news/A7o5ygz_wRFqmYAz9tD1rbw
If "fully loaded" is in the $38K range, I'm still interested in seeing what's not included to reach that price.
klossfam
Jeff
East Amherst, NY
2022 Ford F-150 Lighting Lariat ER, 2025 Ford Mach-E Premium
That's my concern. I drive a 2022 Lightning Lariat with the 511 and every option...plus all the Forscan mods I could muster... I'm used to having lots of THINGS! I'd pay $50k if the platform is truly good and loaded with useful options.
red_blazer
Tony
2024 Honda Accord Hybrid Touring
I have a Honda Accord Hybrid Touring and the MSRP for the top trim is just over 40k. The base MSRP is 28,500 plus destination. It is possible the Lariat or whatever the best trim Fathom will be is fairly well equipped.
graycorgi
East TN
'22 Kia EV6
The longer they go without mentioning specs, the more I suspect that a big omission to hit that price point is going to be decent DC charging speeds.
klossfam
Jeff
East Amherst, NY
As long as 150kw, then only the charging curve matters. The battery will be relatively small. I've had 800V Hyundais, 400V GM/Honda, 400V Fords. The best charging: the 400V Lightning due to a good curve and a battery able to absorb amps.
That being said, assuming the max battery size in the Fathom is 70kwh-ish, that will impact its ability to handle the highest amp outputs. Still, a small battery averaging 120kw pull charges quick.
Several dealers have mentioned that we will be pleasantly surprised by what is included in the base price. I suspect most of the cost of a "top trim" will come from a larger battery. It makes sense for Ford to flatten the feature curve as much as possible to keep costs down. I'm just curious how the top trim compares to the Maverick's top trim.
Extended range battery and AWD for sure. Wouldn't be surprised if some of the other extra cost is a charge for a special tri-color paint and leather this/leather that. Fancy rims. Heated everything. Etc...
graycorgi
East TN
'22 Kia EV6
The charging curve on any 800V HMG vehicle is still better than the Lightning's charging curve. Lightning with larger battery takes almost 40 minutes to charge from 10% to 80%. EV6 takes 18 minutes. Average speed during that time is 139kW vs 173kW. The Lightning is not terrible, but it is not better than 800V Hyundai vehicles.
Now the measurement that actually matters: I can get over 200 miles of range in 20 minutes in my EV6. From 10-80%, it charges at 10.66 miles / min (Lightning is only 5.64 miles / min). The Fathom will need to be able to do 200 miles in 25 minutes or less, otherwise I'm gonna have to pass.
klossfam
Jeff
East Amherst, NY
You aren't factoring in the real world conditions. In summer, 800V charging adds a ton of heat, so your 10-80% which is real in 18 mins causes you to jump back on the highway with pump and fans going full blast. 2.0 mi/KW for 10 miles.
Charging speed advantage tricking away. I've owned and road tripped all these. I know the reality.
Plus comparing 3.2 mi/KW on an EV6 vs 2.2 or less in the Lightning is irrelevant. Real world, yes a EV6 or Ioniq 5 is much more efficient but not apples to apples.
I've had a Leaf, Mach-E GTPE, and currently a Denali Sierra EV truck.
For my personal use case, the charging curve rarely even determines my enjoyment because I can charge at home. Where my sleeping curve is far more crucial to my happiness. 🤣
Having said that, I admit that DCFC matters on the long rides from home. But with the monster sized battery in the truck, I still don't have to stop very often. And when I do, I don't mind lalligagging for a few minutes, if that's what it takes to get the range I'm needing before heading back out.
