- First Name
- Steve
- Feb 25, 2026
- Coppell, TX
- 2023 Ford Maverick XLT Hybrid
- Thread starter
- #1
Take a look at this article on the Mach-E Forum:
2025 Mach-E Heat Pump Technical Info
Note this:Information on the new heat pump has now been published. It is a vapor injection heat pump which means it's capable of operating at low ambient conditions. In short, the new heat pump system is very complicated. It can operate in 8 different modes.
Since the Fathom is going to Zonal architecture with 5 Zones and No CAN Bus (uses Ethernet instead) I wonder if the Heat Pump system was redesigned (skunkworks) from the ground up for the Fathom (Universal EV Platform)?The Ford Vapor Injection Heat Pump (VIHP) system is primarily managed by one dedicated local control module known as the Heat Pump Valve Control Module (HPVCM).
Control System Overview
- HPVCM (Heat Pump Valve Control Module): This dedicated unit directly commands and controls the electronic expansion valves (EEVs) and overall operation of the vapor injection loop.
- Integrated Network:While the HPVCM is the dedicated sub-controller for the physical valves and refrigerant flow of the VIHP, it does not work in isolation. It relies on data inputs and communication shared across other primary vehicle control modules via the CAN bus, including:
- HVAC Control Module (processes cabin climate requests and ambient/interior sensor data).
- PCM (Powertrain Control Module).
- SOBDMC (Secondary On-Board Diagnostic Control Module)
