Are EV-Specific Tires Better than Popular Non-EV Tires?
EV tires are typically heavier load rated and low rolling resistance (LRR) for range.
Tires will wear faster on EVs due to the increased weight.
And Ford may change their OEM tires many times before the production release.
My OEM Mach E tires lasted 30,000 miles and switch to run flats (RFT) due to lack of a spare.
Now I can drive confidently without worry of a flat tire having to pull over immediately - 50 miles of distance available on zero pressure!
We hashed this out way too much on the Lightning forum.
There is nothing special about an "EV" tire. The ones that came on Lightning were flimsy little 4 ply Goodyear tires, despite the truck's 6,500 lb. curb weight. That basically proves that any aftermarket tire will work just fine.
As far as wear goes, we've seen 8,000 lb. heavy duty pickups go 60k to 80k miles on a set of tires, so why should a more lightweight EV truck be any different?
I've reviewed a lot of tires for my channel over the years and in my opinion these "EV" tires are a marketing ploy. I would prefer a lightweight all-terrain tire on my truck, EV or not, because they are less likely to suffer flats.
Just remember, the load rating is more important for EVs.
When I got replacement tires, I opted for run flats (RFT), higher load rating and larger + wider tires that I can pressurize lower than OEM tires.
Makes for a much better ride !
+4 on tire size upgrade w/ wider wheels:
Ranchero EV Pickup Truck Are EV-Specific Tires Better than Popular Non-EV Tires? IMG_4053 5
Finnster
N. E. Wisconsin
Chevy, Kia, and a 2025 Maverick Hybrid 4K Tow
@metroshot, Do you happen know what the vehicle efficiency penalty was of the switch to +4/lower psi tires?
Penalty is about 10% range decrease at high speeds - combination of larger & wider tires, wheels, and 2" lift.
None noticed at low speeds, daily commuting, and city driving.
I hope for tires that withstand having a loaded bed or pulling things. I'm ok with a range penalty in this case.
Recent long distance trip yielded something interesting:
Increasing tire pressures to 39 PSI on the tires increased range to almost what I used to get before the OEMs got switched out.
Ride is stiff, but the range was better.
When I got back home I reduced pressure to 33 PSI and comfy, soft ride for the city.
Typically even the least expensive P-metric rated tires have a combined load rating of 10,000 lbs. or more for a set of four. The Fathom will probably end up with a GVWR of around 6,000 lbs. So any tire you put on a Fathom will be overkill. It'll be fine.
