Toyota Highlander EV 3 row SUV
Pretty sure the VOLT, which by many accounts was a decent first-attempt at an E_REV was programmed to run the ICE occasionally just to make sure nothing got stale, got the lubrication going, etc. It wasn't often, and it wasn't for long, but the VOLT owner didn't need to know nor care.. the ICE got its exercise as needed. Seems like a simple programming function for any decent eREV to include.
I agree that any ICE would best need to be periodically run. I've a Miata that sadly doesn't get much drive time in these days. I still make it a point to take it out every month for at least a 1/2 hour to get the oils up to temp and give it a little love.
I'm guessing that there will be engineering for EREV to address fuel age concerns. Similar to the example that was just given regarding the Volt.
I wouldn't be surprised if there are onboard settings and choices for the driver to choose to run the generator ICE intentionally, even when it might not be necessary?
Our Ford Escape PHEV has options to go EV first, EV later (for driving into a city where there may be restrictions), or EV auto (mostly EV but goes gas under highway load/speeds). I think E-REVs would also have something similar.
NM
2001 Ford Ranger; Volvo EX30 AWD
I think commodorebob mentioned that their explorer got 500 miles and the switch to 300 of the Toyota would be disappointing. I was assuming he was talking about battery range. I did hybrids, but I’m done paying for gas these days.
I understand the concept of E-REV. It sounds pretty reasonable, but gas goes "bad" after a period of time. The additives that one can use to extend the life of the gas don't last forever. Is there a long term solution for the storage of the gas that powers the generator for a person who plugs in the vast majority of the time and doesn't use the generator often?
That’s where even an EREV isn’t for everybody. If you never drive more than 100 miles then an EREV isn’t a good idea. I would also prefer only a 10-15 gal tank so I can go through it in a few months. I rarely go more than a month or two without a 300+ mile drive.
Seems to me if you 'never' drive more than 100 miles, but say more than 20 a day, the e-rev is actually perfect.
To me, the best selling point of an e-rev is that there's NO range anxiety -AND- NO charging anxiety as long as you have at least a 120v outlet where you can top off nightly (say adding 40-60 miles a day). No need to add a $$$ 240v level-2 (though it's good if you can get it),.
There's no hassle with level-3 charging/apps, and never a worry if you do one day need to go to work, go to the store, go to the dr. Life happens, and a worry-free EV should be more accessable than a full-bore EV with the much larger (3x?) battery pack, especially if you can only have ONE ride in the stable. With an E_REV, you still drive a displaced-emission vehicle at a lower cost per mile than gas for nearly all your drives, but without the hassles of going full EV for everything.
Imagine a scenario where some genius invented a paint that collected solar energy, and it was so efficient at doing so that if you equipped an EV with that solar paint, it could charge the EV battery at a rate that it could extend the range of the EV as long as there was enough sunlight to backfeed the HV battery at about 1/2 the rate you were consuming it.
That would technically be an EREV, right?
Would you want it over a pure EV?
How about if it added to the price of the EV the equivalent of the price an ICE-generator does? And pretend it adds similar weight?
My point being is that I think some of the objections to the current EREV design is just an objection to ICE/petrol. Which is fine, of course, but be honest and admit that's the negative.
The concept of traveling down the road and having the ability to backfill (charge) the HV battery in an EV is awesome! It's just that currently we are limited to the method(s) of version 1.2(?) of doing so.
Our PHEV has a vacuum sealed tank that keeps the fuel fresh.
Never had an issue since 2018 with fuel that doesn't get used at all.
Plus once a month it starts up the ICE just to make sure everything works.
Slightly smaller than an Expedition but likely to be priced the same. Given that we get over 500 miles a tank on our Expedition, 300 miles is a bit short.
In any case, not a direct competitor to the Fathom given the size and likely price difference.
It will be competition to the future 3-row crossover that will be on the Ford Universal EV Platform.
Ford's Universal EV (UEV) platform is a flexible, cost-optimized vehicle architecture designed to build a profitable family of affordable electric vehicles at scale, starting with customer deliveries in 2027.
Key Details & Goals
  • Target Pricing: Aiming for a $30,000 starting price for the initial model.
  • First Vehicle: A midsize, four-door electric pickup truck built at the Louisville Assembly Plant in Kentucky.
  • Supported Body Styles: Engineered to back up to eight different body styles, including compact, midsize, and three-row crossovers, sedans, cargo vans, and passenger vans.
  • Manufacturing Innovation: Uses an "assembly tree" concept where front, rear, and structural battery sub-assembly lines run parallel before joining, cutting workstations by 40% and assembly time by 15%.
  • Battery Tech: Features structural cobalt-free and nickel-free lithium iron phosphate (LFP) prismatic battery packs serving as the vehicle floor for a lower center of gravity and weight savings
garbage ADAS. Mid to drive
Yes, it seems that none of the Japanese cars have lane centering with adaptive cruise, like Ford and VW. I think it might be because the Ford and VW systems are supplied by Bosch whereas the Japanese cars use a different supplier. GM purposely doesn’t provide lane centering because they want you to buy Supercruise.
it will be interesting to see if the UEV continues to support standard lane centering with their new architecture or will follow GM and force you to buy Bluecruise. I sure hope they do provide it as a standard feature because it works so well.
GM has recently chosen to treat their 2027 Cadillac EV customer special, it appears. It is the one vehicle that they "unbundundled" Lane Centering from Hands-free.
It infuriates me, something not easy to do, when I get out of my 5 year old F150 with full time Adaptive Cruise/Lane-Centering, and into my 2025 EV Sierra and experience Lane-Centering nixed for any road that doesn't qualify for Hands-free.
Current versions of both Bluecruise and SuperCruise are almost indistinguishable, in my two trucks, when the travel is on well defined straight roads. Bluecruise (1.4) does appear to have a slight edge when the road conditions are more challenging.
Ford seems to be less stingy with the technology when you choose not to subscribe to Hands-free. They allow you to experience virtually the same driver's aid, albeit with requiring you to acknowledge you aren't invited to take your hands off the wheel. Something I personally don't do even in a Hands-free mode.
Agreed. And that is why there is no GM EV in my driveway. That and the lack of CarPlay/AA. Although I’ve heard GM is under tremendous and increasing pressure from their dealers to get CP/AA back.
Nice to hear lane centering is now implemented on at least one vehicle, but I have no interest in driving an Abrams M1 Escalade. GM can be so petty.
