Ford Fathom Design Wishlist: High-Efficiency Colors & Smoother Multi-EV Home Integration
crainwii
William
Sacrament, CA
2022 Ford Explorer, 2024 Ford F-150 Lightning Flash
Hey everyone,
With the Ford Fathom on the horizon, I've been refining my blueprint for what Ford's next-gen EV should bring to the table. As a current owner of a 2024 F-150 Lightning (Extended Range battery), my focus is heavily split between maximizing thermal efficiency and securing a more streamlined home integration ecosystem.
Here are the specific exterior, interior, hardware, and software features I want to see:
Thermal Efficiency & Color Design
  • Exterior Palette: A focus on highly reflective, ultra-light colors like stark whites, silver metallics, and light platinum shades. Choosing a light exterior helps reflect solar radiation, significantly reducing cabin heat soak while parked and lowering the energy needed to cool the vehicle.
  • Interior Environment: A matching, light-toned cabin environment (such as light gray, cream, or sand) using low-emissivity, eco-friendly materials. Keeping the cabin surfaces light helps minimize heat absorption in the summer and retains climate control temperatures more efficiently year-round, conserving vital battery range for driving.
Hardware & Range Extension
  • Solar Panel Bed Cover: An optional, rugged solar tonneau cover integrated directly into the truck’s high-voltage charging system. This would provide passive trickle charging to the battery pack while parked outside, maximizing range extension and helping run auxiliary onboard power without draining the main traction battery.
Ecosystem & Software Integration
  • Unified Utility Onboarding: A native, plug-and-play software walkthrough inside the FordPass app specifically optimized for regional utilities (like SMUD).
  • Intelligent Dual-EV Power Sharing: Hardware and software designed to seamlessly split home charging loads between an existing Lightning ER and the new Fathom without tripping breakers or requiring expensive secondary switchgear.
  • Simplified V2H (Vehicle-to-Home) Steps: A clear, foolproof installation and activation wizard in the sync screen so users don't have to hunt through conflicting documentation to get their backup power running.
What are your thoughts on combining light colors and a solar bed cover for peak thermal and battery efficiency? Would you buy a solar tonneau cover option?
My concern would be on a tiny little bed, like what we're going to end up with on this truck. Is there enough surface area to provide enough solar panels to do any good? I've seen guys on the F-150 Lightning Forum try things like this and even gasoline-powered generators mounted in the bed to provide additional power, with limited success. I do, however, agree with you 100% on the fact that lighter colors do have a higher albedo, which is to say that they reflect more solar radiation and would ideally be better suited for an EV. Oxford White has always been my favorite color on Ford vehicles, so I'm in pretty good shape because I'd say there's a 99.9% chance that will be one of the options.
+1 regarding a solar truck bed. That's a LOT of extra costs to gain just a few kWh on those occasions where you're parked under clear skies on a bright, bright sunshiny day.
Assuming a 54" x 54" bed size, that's ABOUT 22 square feet of space for solar panels
For comparison - a SINGLE 400 watt solar panel size about 75" x 44" = 22 sq ft.
...So at best you're looking at 400 watts. That's .4kW. If the vehicle sits in direct sunlight all day for 12 hours (and the earth stops turning so the sun is always directly overhead), I think, at best, you'd only gain about 4.8 kWh. If the truck get 4 miles/kWh thats 19.2 miles.. Obviously the real number will be lower as the angle of the sun reduces the solar cell output + shadow from the cab, shade, any clouds, time of year, etc that will reduce the daily total kWh put back into the battery (and there's also going to be losses in charging circuit too).
I'm all for green energy, but a fixed solar farm with banks of storage and distributed to the grid, or even just a bank of solar cells and a storage battery system at home, seems to make more sense. Putting fragile solar cells on the bed cover wouldn't appear to be a good practical solution for most of us just to add 10-20 miles ( some residents of Arizona and New Mexico might be excluded).
Where I live, it's about $0.12 a kWh residential rates - 4.8 kWh is $0.57 worth of electricity from our utility.
Garbone
Gary
21 Mach E , 22 MachE, 62 C10 Big window long bed
Need Red.....
Nice analysis. Puts the value in perspective. We get alot of sunny days in Florida, but unless the vehicle is in use, it’s in the garage so I don’t cook when getting in so the value of the solar diminishes. It is a cool idea though. When I worked and parked outside this would have paid for the the trip home. The susectibility to damage would concern me as well.
If you work less than ten miles from home, you are effectively getting your travel cost for free. I like the idea of a solar bed cover. It's an extra 8 miles of range in an industry that maximizes range.
TNFurb
Kelly
Nashville
ā€˜23 Bronco Sport OB ā€˜24 Mav Lariat Hybrid
Totally agree on the exterior and interior colors.
Pogeegitz
Adam
Minnesota
2022 Ford Maverick XLT 2.0L
Being from the frozen tundra, I'm less concerned about solar heat gain and solar charging. From working as an engineer in building materials, the added costs of focusing on those things are rarely offset by the savings over the life of the product. I also want a truck to do "truck things," which doesn't do well with white interiors. Offer those things as a premium energy upgrade for those that want it, but don't burden the entire population with (mostly) altruistic desires.
smoreho2
Stephen
manassas virginia
2023 ford maverick hybrid xlt
Hey everyone,
A minimum 5’ bed and add a slightly bigger cabin. Max overall length 215ā€.
PowerShift
Maryland
Ford Fusion Hybrid
...I also want a truck to do "truck things," which doesn't do well with white interiors. Offer those things as a premium energy upgrade for those that want it, but don't burden the entire population with (mostly) altruistic desires.
It was not so long ago you had a choice 2, 3, or even 4 interior colors for a car at no extra cost.
Since it’s sounding like there’s only gonna be one trim, I’m guessing active x seats are standard, and will come in a light and dark color. Maybe ebony and light space gray?
Jasonkola
Jason
2004 Ford F150
I would be ok with light interior but not the heavy use areas like the seat, carpet or steering wheel. Those light colors will just look like crap after a few years. I hope Ford makes an SUV off this platform. I might go for that if it has good towing capacity. Also good ground clearance.
TNFurb
Kelly
Nashville
Ford definitely has plans for a crossover/SUV in a couple of sizes I believe. Honestly, I wish they were coming out with the escape replacement on this platform before the Fathom as I want an electric car for my around town driving in metropolitan Nashville area but I’d like to keep my Maverick for longer distance travel. Just not sure I’m going to be able to hold off long enough to wait on the crossover 🤪
