Ford Fathom Design Wishlist: High-Efficiency Colors & Smoother Multi-EV Home Integration
bob zimmerman
northern MN
25’ Maverick XLT AWD
I don’t wish for much.
My wish for the Fathom is that everything works.
I wish that something as simple as the truck remembering my settings when I get in it each day won’t be as poorly designed as my Maverick which makes me start over with basic screen settings Every time I get in.
The more electronics they put in these vehicles, the more headaches end-users get. Everything about the truck can be absolutely amazing but something like your phone intermittently not connecting to the truck can drive a person mad!
Nobody complains about all the things that work flawlessly.
If I can touch it and see it, it has to work every time. Not most of the time.
Ecosystem & Software Integration
  • Unified Utility Onboarding: A native, plug-and-play software walkthrough inside the FordPass app specifically optimized for regional utilities (like SMUD).
  • Intelligent Dual-EV Power Sharing: Hardware and software designed to seamlessly split home charging loads between an existing Lightning ER and the new Fathom without tripping breakers or requiring expensive secondary switchgear.
  • Simplified V2H (Vehicle-to-Home) Steps: A clear, foolproof installation and activation wizard in the sync screen so users don't have to hunt through conflicting documentation to get their backup power running.
In a sub $30,000 vehicle?
There is a reason the current system offered by GM and the former system by Ford cost $10,000+ and still doesn't work...
This is a very complex and complicated ask. I don't see it happening at this price point.
If you watch Tim Bartz's video on the Fathom (he's a darn reliable source of information), he seemed kind of shell shocked at what kind of standard content you got with the Fathom. He was shaking his head wondering if it was going to disrupt sales of other Ford models, because you just get so much for your money.
UEV was created to disrupt the status quo of the automotive world.
That means getting more for your money not because Ford is taking a profit hit, but because they threw out the cookbook and innovated like their paychecks depended on it.
On Autoline After Hours, the host loves throwing out the line "In Big Auto, the surest way to get promoted is to always say NO to risky new ideas". Well Jim Farley threw out the Big Auto playbook, and launched a bunch of rebels with simple instructions: "Say YES".
Farley called the UEV Ford's next "Model T Moment" and looking back at that history, I can see how that makes sense. Ford reworked the entire assembly line to drive the Model T costs down so it is affordable for everyone. It sounds like Ford is trying to take the same approach with the UEV. Make your profit on volume with a vehicle that has some ongoing subscription options (BlueCruise, internet) to round out the balance sheet.
You want all of the electronics to work year one? That ain’t happening at any price point.
dimes4slim
Gary
Murrieta, CA
25 Mach-E GT
Probably not happening at ANY price point. If it weren't for OTA, you would see less EV's on the road and more in the shop.
Since it’s sounding like there’s only gonna be one trim, I’m guessing active x seats are standard, and will come in a light and dark color. Maybe ebony and light space gray?
Recent update from Tim at Long Mcartur was there would be at least two trims offered at introduction. Implied extended battery range and AWD. Video 251 as I recall.
I hope a trailer hitch is built into the truck as standard. I had one installed by the deaaler on my Rene and it was not properly installed ( missing bolts) and still cost $700 12 years ago. Proper integration is best done at the factory and is cost effective.
On the maverick it comes with AWD. I expect it will be the same due to additional power from the second motor needed for a decent towing capacity.
Makes sense. Thanks. I plan on the ER and AWD trim.
I like my Maverick. So, the Fathom needs to at least offer feature parity, or there is no point in even looking. Given that I am averaging less than one tank of gas per month, I do not need the EV for fuel savings. I am aware that many of these would likely require a higher trim level. I am willing to pay extra. While I understand the base Fathom will have more features than my Maverick, there are still certain features it has to offer if I am going through the trouble of upgrading.
I'll update this list as I think of more things or change my mind.
Must Have (Not buying without these; some already confirmed):
  • BlueCruise.
  • Vented seats.
  • No mid-gate. A sealed gap in the frame is still a gap through which water, air, and fire ants can enter.
  • A bold blue paint of some kind or factory wrap option.
  • Option for a spare tire.
  • Ability to turn off one-pedal.
  • Under-seat rear storage.
  • A trim with options that are at least on par with the Maverick Lariat.
  • Physical door handles. I don't care if they are flush, but it needs to be mechanical.
  • An appearance that is more truck and less cyber.
Could Use (Won't stop me from buying but will help push over the line):
  • Integrated power bed cover option.
  • Option for a full-size spare tire.
  • Digital trailer mirrors.
  • Split under-seat storage.
  • Power tailgate.
  • Fog light option.
Would be Nice (Wishful Thinking):
  • Solar panel bed cover option.
  • Air suspension.
  • A bed size identical to Maverick's, so I can reuse my existing accessories.
  • Autopark.
  • Under-bed storage compartment.
  • Some available merch.
    • Shirts
    • Caps
    • A Fathom-branded battery bank
By that logic, wouldn't the single motor, Rear wheel drive variant also need the structure?
Difference being on a Maverick the "single motor" option is front wheel drive. It's the opposite on the Fathom.
A minimum 5’ bed and add a slightly bigger cabin. Max overall length 215”.
4 1/2 foot Maverick bed works fine for me.
Hope the Fathom has the Midgate everyone is speculating on.
Length over 205" means it won't fit in my garage. So no to that.
It is bigger (more volume than a Maverick) Tim confirmed.
OTA updates to fix any issues found after delivery. No need to go to a dealership.
Also the team working on the Fathom has about one year from now to test fix test (rinse & repeat) to flesh out issues and fix them before the first Fathom is even delivered.
Hcopter
Mike
KS
1996 Ranger, 2023 Maverick Lariat, Hybrid
  • BlueCruise.
  • Vented seats.
  • Power tailgate.
  • Fog light option.
  • Air suspension.
  • Autopark.
    • Shirts
    • Caps
It surprises me that so many people dislike one-pedal driving, I wish my Maverick could do one-pedal. I've driven over 2000 miles in various, rented Teslas and always miss one-pedal driving most when going back to my own vehicles, gas to brake, gas to brake vs just smoothly modulating the accelerator as needed and rarely moving my foot from the pedal.
