- First Name
- Mark
- Jan 7, 2026
- Silver Spring, MD
- 2021 Mustang Mach E, 2022 F-150 Lightning
I can tell you that this was one advantage Alan Clarke saw in the collapse of Model E back into the main Ford hierarchy. When I asked him about that move, his response was that he was very happy to see it. In fact, the said it switched the position of the EVDC from a novel development program in an off-branch of Ford to a development facility that was already influencing how Ford was thinking about manufacturing across its entire lineup. While he seemed to be speaking more in terms of the assembly tree, I think it applied to vehicle architecture as well.Wondering if moving forward, Ford will use this new wire harness across the lines and put everything from F750 and E-Series right on down to all the other Fords to a 48v zonal system.
Just remember, you can only eliminate the LVB if you have a HVB to provide power. The approach won't work on a fully-ICE vehicle. You could switch from 12v to 48v as long as there is a 48v or larger battery (BEV, EREV, PHEV, or HEV).
